Tabbing Order Problems
I am trying to change the tabbing order of my front panel, but anytime I make changes none of them stick. I can go back into the tab order editor and see that the order is exactly how I set it, but when I run my VI the tabbing order is the same as it was before I ever tried to change the tabbing order. Am I doing something wrong or is this a bug?
(3,124 Views)
Accepted by topic author bend2252
Any chance you can post the VI so we can try for ourselves?
If it works for other people then you're doing something wrong.  If it works for nobody it is likely a bug ... though to my knowledge there are no bugs associated with tabbing order.
(3,120 Views)
It turns out there isn't a problem. I didn't realize that while I'm tabbing through my front panel the indicators get skipped, even though they're in the tab order.
(3,105 Views)
