Table control and Print
Hello everyone,
                  I have a table control. Values in the table will be saved in spreadsheet file. Now, when I press a button ( in my presnt case its for print) i shoud get direct print of atleast print pop up window. Is it possible? Taking print directly from  table is possible??? Or should i access spreadsheet file and do it?
Thanking you,
Sushmith
(2,634 Views)
Hello everyone.
              I can open the saved file manually and get print or through labview I can open the file so that from there i can go for print. But actual requirement is data from file will be displayed in a table control and when i press print button automatically it should be printed checking the printers available or should pop up a printer set up window so that I can select printer manually and give print.
Thanking you,
Sushmith
(2,624 Views)
