Table control data update with LED status progress
Hi Friends,
I've a requirement for my project....
But i am not clear of how to implement that.
The main.vi will extract the data from an Excel sheet using all excel.llb and show the data in table  control.
At the back end i'll be keep on reading data from the worksheet 1 of the excel sheet.
so my intention is something like this
whenever it reads the 1st row  of data the LED should blink at the first row and it proceed down as per the for loop
And should continue up to the end.
If anybody have worked out with the Table control and Excel sheet VI's please help.
Your help would be appreciated.
Will attach the VI on request.
Cheers,
Suneel.V
Message 1 of 23
(4,903 Views)
Hi Suneel,
i think it is not very effective. You can read the data of the entire sheet with one ActiveX function, just define the relevant range.
If you really need it, define the range for every row to read your data row by row and move your LED indicator.
Hope it helps.
Mike
Message 2 of 23
(4,901 Views)
Hi Mike,
Thanks for your prompt response.
Attached are the VI's.
The main VI is Excel_Tablecontrol.vi and the sub vi is excel_read.vi
In the main VI select any excel sheet from your PC and it will extract the first sheet data in it.
But in my real project i will be reading line by line.
Could you please make me clear how should i put an indicator whcih would go line by line.
Message 3 of 23
(4,898 Views)
Hi Mike,
Cheers,
Suneel.V
Message 4 of 23
(4,897 Views)
Hi Suneel,
see the attached example.
Mike
Message 5 of 23
(4,894 Views)
Mike,
Yes, this is the example i'm looking for, i'll try to use the same login for my VI and will keep update you.
Thank you.
-Suneel.V
Message 6 of 23
(4,891 Views)
read login as logic...
SOrry
Message 7 of 23
(4,890 Views)
Hi Suneel,
you can edit your message within 10 minutes. Smiley Happy
Mike
Message Edited by MikeS81 on 07-04-2008 09:04 AM
Message 8 of 23
(4,888 Views)
Hi Mike,
THis VI is having some bug ...
THe LED is going out of table control if the Table control size is minimized
And also onemore thing....
SInce the data is less its ok
what if data is some 100 lines....
will the sroll bar automatically moves down and also the LED should move down parallely....
Run this VI
Cheers,
Suneel.V
Message 9 of 23
(4,859 Views)
Hi, suneelkv,
Are you sure that you need Boolean? It looks nice, but you should figure out, how to synchronize position of the indicator with proper line every time, when table scrolled, moved, etc.
Probably solution with Symbols will be better for you?
Andrey.
Message 10 of 23
(4,854 Views)
