Table hard to scroll with cell background color
When I altered cell background color, the table become hard to scroll.
And I can't finish alter cell background color, it takes forever.
Anyone run into this problem before?
LabVIEW 2011 on WinXP.
George Zou
(2,790 Views)
Accepted by topic author zou
Hello Zou,
The problem is not with 'Cell Background color'.
But the problem is with 'Size of the Table'!
When your table size is huge, the windows+LabVIEW graphics are taking more time to scroll.
Attached VI can help you to experience the same. Change the table size and experience the scroll.
Solution:-
1. Initialize the Table to only the maximum size, If your table size is small.
2. Use Table(UI)+Scroll Bar(Manual from Numeric Palette)+Internal Buffer(Block Diagram), for huge table size
Yogesh Redemptor
Yogesh Redemptor
(2,772 Views)
If I remove cell background color, I have no problem to scroll.
Index -2 is the key !
I set individual cell background color instead of whole row.  I thought that might use less memory. It seems just opposite.
Thanks for the test VI.  I set the table size to the same as mine, it finishes changing cell color in a few seconds !  Mine takes forever !
George Zou
(2,756 Views)
