Table of LabVIEW Windows requirements vs LV version
I know NI must have a table somewhere that shows which versions of Windows are required for the different versions of LabVIEW Full Developement.  Can anyone point me to the page?
Thanks.
Roy
(4,178 Views)
I don't know if this information is available in any place other than the requirements for each version (which are probably available as part of the user manual or a readme file on this site), but basically, all recent versions will run on 2000 and XP (and presumably Vista as well in comptability mode, although the hardware part is more complex because you need Vista drivers.)
If you want 98 then the most recent version you can use is 7.0.
___________________
Try to take over the world!
(4,162 Views)
Hi Roy,
The system requirements for our software are noted in the release notes for each version of LabVIEW.  Here is a link to a page with links to different release notes for versions of LabVIEW going back to version 4.1.
http://sine.ni.com/manuals/main/p/sn/n16:en,n17:ReleaseNotes,n23:4.28.369.845
Justin D
(4,143 Views)
Justin,
Thanks for the reply (just looking over old posts).  This will get me what I need, but I still think NI should create a single list of all software, versions and compatable Windows versions.  It shouldn't be that difficult.
Roy
(3,754 Views)
Accepted by topic author RoyA
RoyA wrote:
Justin,
Roy
There is for Windows 7 and for XP/Vista, . Was there something in particular you were looking for?
(3,731 Views)
smercurio_fc,
Thanks, that's what I was looking for.  Is there a similar list for earlier versions of Windows?
Roy
(3,701 Views)
I don't recall ever seeing such a list compiled for earlier versions. As far as LabVIEW is concerned, the compatibility list can be found here: Which Windows Versions Are Compatible with LabVIEW.
(3,683 Views)
