Table property CellFGColor missing in LabVIEW8?
Hi all!
LabVIEW8 keeps me surprising all the day:
For a table control, I can't find the property to set the foreground color of the cell. Earlier versions of LabVIEW (at least v 5.1.1) there was a "CellFGColor" property available.
In LabVIEW8 list of properties, there is only background color (CellBGcolor) available. It seems that new NI has forgotten foreground property somewhere during reorganising properties for LV8...
Where can I find the property to set the cell foreground color programmically???
Thanks!
Wirer
(2,795 Views)
The property which you will use in LabVIEW 8.0 is the Cell Font Color rather than CellFGColor.  This property is found in the list at  Active Cell : Cell Font : Color.  The new property configuration also gives you control over a wide range of Font properties which were not available in prior versions of LabVIEW.
(2,766 Views)
