Table shifting issue
I just discovered an issue in LV 2013 table controls. Pressing "Enter" should move the active cell to the next one in the column. It works as it should if the cell's right bound is visible.
However, if the right bound of the cell is beyond the right side boundary of the table(i.e. like the pictures shown below), pressing "Enter" will always move the active cell to the first cell on top.
Anyone has any ideas how to solve this problem?
Thanks in advance.
(2,857 Views)
Awang,
It looks like you might have put the wrong pictures for your second example.  I was able to recreate the issue I think you are having though by placing a table control and selecting a cell on the very right of the table when the entire cell is not visible then pressing return.
The workaround really just seems to be making sure you correctly size your table or having the horizontal scrollbar visible.
(2,837 Views)
