Table with multiple headers in labview
I want to create GUI in labview as shown in attachment.The column number may be different for each row.(Any feature like merge cell or split column in excel?) Is this possible using tables?
Or any other data structure is there for creating similar GUIs?
Please help
(4,449 Views)
       I want to create table with multiple number of columns inside a column (nested rows and columns)  as shown in the figure.In each row the column number may be different. Is there any provision for creating table like this in LabView.The same data have to be logged to apdf or word file also.Please help...
(4,477 Views)
I suggest creating an Excel file and doing the cell merges/formatting manually, then save it as a template. Using the Report Generation Toolkit, open the template & fill in the cells programmatically. This toolkit can also be used to export as pdf.
(4,443 Views)
How to open an excel template in pdf toolkit?
(4,421 Views)
You can embed excel into your VI. Here example
(4,432 Views)
Its not working. Not able to open excel in browser
(4,425 Views)
Search for "Excel" in "Find examples" in the help-menu in LabVIEW. There are some examples there.
Certified LabVIEW Architect
(4,378 Views)
