Table
How do you get numbers from a Microcontroller into a table in LabVIEW automatic?
(3,031 Views)
LV tables accept only data as 2D string-array.
You have to convert your numbers to strings according to the number format (use the number to string functions), and build-up a 2D array that you will display on your table.
(3,031 Views)
