Take and delete a String from another String
I have original input string= 111100001111
I need to Take for example the least 4 bits .... Output= 1111
and to be removed from the original input string so the original input string= 11110000
I am trying to make a generic one but the point is that I can not delete subset that I take from the original input String.
How can I take and delete from a string in the same time?
(3,683 Views)
Something about this makes me think that a string isn't the proper data type to be using, but this does what you've asked.
That't the "Search/Split String" primitive.  You'll have to do some math if you want the last four characthers (not "bits") of a variable-length string.
Jim
(3,673 Views)
Can I find a way to update the String constant "1111000011110000" with the" match + rest of string" after each loop iteration ?
(3,649 Views)
Accepted by topic author MarinaNashaat
Something like this?
(3,637 Views)
