Take out one bit from a 8-bits number
Hello!
The problem is that we want to pick out only the one bit the we make "and" in the attached VI. And if the next case is "Inverted" or "Not Inverted" then we want the bit to be inverted or not inverted. So we want to get either one 0 or one 1 on the output. Any idea? See the attached VI. Thank you and best regards.
(2,403 Views)
Hi
I can't look at the vi you posted because it's LV7.1, but according to your question I worked out a simple solution.
I hope this is what you are looking for.
Thomas
Using LV8.0
Don't be afraid to rate a good answer... 😉
(2,399 Views)
Hello! Thank you very much for your help! You had a solution that solved our problem 🙂
(2,390 Views)
