Taking a fft of a audio signal
Hey Dennis
Is the rest of the code right because I added the VI in but it still doesn't give a good graph. I also have to log the y range if that makes any difference
Thnxs again..you're been really helpful
Message 11 of 31
(2,861 Views)
I posted a VI here. http://forums.ni.com/ni/board/message?board.id=170&thread.id=163587 It is crude but i may give you a jump start
Besides which, my opinion is that Express VIs Carthage must be destroyed deleted
(Sorry no Labview "brag list" so far)
Message 12 of 31
(2,858 Views)
thanks for replying t06afre but mine is way simplier than this. I have mine posted  if you could have a look at it and see what is missing
Thanks in advance
Message 13 of 31
(2,852 Views)
Maybe but my VI is actualy giving some usefull output....................Your vi is just some functions tossed out on a diagram. You have no understanding of what you are doing. And you are no interest in learning something.I guess you are just fishing for an easy way out, for your homework
Message 14 of 31
(2,838 Views)
the audio signal is coming from the mic so i put in a acquire sound vi but where do I connect it to in your program
Message 15 of 31
(2,827 Views)
Hi Moe
I have to admit that converting a dynamic data into something useful is not straight forward for a beginner. The Express VI concept is just flimflams glued into labview with cheap glue. It is also poor documented. None of my students are allowed to use Express VIs in their lab reports. I want them to learn Labview. You can not learn labview by tossing in some functionality into a block diagram. Since how to convert dynamic data to waveform data is not documented. I have made a small sample VI showing how to do it. Remember also that my FFT VI need some work to fit your need. You have to connect the delta t control to a terminal on the VI connector block. But it works. I have tested it
Message 16 of 31
(2,807 Views)
Thnxs a lot for replying
I'm still having problems. The output that I have is just not the same as the DSA. Where do you connect the dt into? and honestly if you have time if you don't mind explaining wut the dt portion of it does?
Thnxs again
Message 17 of 31
(2,783 Views)
When you read from a sound card your output is not in volts but in raw A/D steps that equal the resolution of the A/D in the sound card.  For example, a 16-bit A/D would range from -32768 to 32767 for a total of 65536 discrete steps.  These numbers have to be scaled to the voltage range the A/D is wired for.  If your mic input is wired for a voltage range of +/- 10 mV then you would have to use a scaling factor to scale the raw numbers to this voltage range (20mV/65536 = 0.3051757 uV per step).
Randall Pursley
Message 18 of 31
(2,777 Views)
what kind of scaling factor would you recommend for volts?
thnxs in advance
Message 19 of 31
(2,770 Views)
Hi Moe
You will find all information you need here http://zone.ni.com/devzone/cda/tut/p/id/4541 and http://zone.ni.com/devzone/cda/tut/p/id/4541. The dt value is the reciprocal of the sample frequency(1/x) The unit is second, and it will give you the time interval between two samples. Now the rest are up to you. I feel I can not give you more help unless you show me some progress in your learning curve
Message 20 of 31
(2,732 Views)
