Taking a picture in LabVIEW with USB camera
Hello:
I am trying to find a way to use a Logitech USB camera (or potentially a different USB camera - perhaps a more expensive Edmund Optics camera) to snap a picture in LabVIEW. I have NI Vision software installed as well as the IMAQ USB extension for Vision, but I'm not sure where to go from here. All I need to be able to do is to snap a photo within LabVIEW and have LabVIEW save it onto the hard drive. Any help would be greatly appreciated.
Brad
(2,837 Views)
See if anything in this thread helps
(2,830 Views)
Hi Brad,
Some of the information in the thread linked above may be out of date.
Check out this article [Acquiring Images in LabVIEW Using a USB or an IEEE1394 (FireWire) Camera] for some advice on how to snap your pictures. If you already have the NI-IMAQdx drivers, you should be able to use these for acquisition (as long as the USB camera is DirectShow compliant).
If you do not have the NI-IMAQdx drivers, but you do have the Vision Development Module you will be able to download the Vision Acquisition Software which includes these drivers. The vision acquisition software can be found here: http://www.ni.com/nisearch/app/main/p/bot/no/ap/tech/lang/en/pg/1/sn/catnav:du,n8:13.79.7820,ssnav:s...
I hope this helps!
Matt
Matt
NI Community Team
(2,786 Views)
