Taking out the string and DBL variables out from a for loop
Firstly, I read couple of previous from post and people are directed to consumer/producer example loops I couldn't manage to make my one work.
I have a VI which reads 100 speed points and graphs them one by one with the for loop I would like to take out this graph out of  the for loop. Secondly, a hex string is generated by concatenating some other constant stuff. I would like to take out this generated string and make a subvi which inputs (tyre diameter,nominal rpm, file path, 5 other pink strings) and output (generated string, and the rpm values and graph them one by one).
Thanks in advance. Yes I know it's been asked and it is in examples but I couldn't make it work.
Message 1 of 9
(3,145 Views)
Well how can we help you make something work when all you provide is a paragraph full of words?
Do you call your mechanic on the phone and ask him to troubleshoot why it won't run?
Message 2 of 9
(3,140 Views)
forgot to attach the VI.
Summary: I want to take the 5 outputs out of the for loop to make a sub-VI which I couldn't manage to. I am asking for help how to do it.
Message 3 of 9
(3,128 Views)
Hi ardahatunoglu,
Your VI will read a whole spreadsheet, not just "100 points".
There are no "graphs" in the VI, just 3 charts.
Where do you fail in "take out this string"?
Why don't you wire the string to your next subVI, with all those other parameters you wrote?
I just placed a flat sequence frame around your 5 indicators: all you need to do is to select this frame and use "Edit->Create SubVI" from the menu…
Message 4 of 9
(3,119 Views)
I still can not make a subVI which has inputs (tyre diameter,nominal rpm, file path, 5 other pink strings) and outputs (generated strings(x2), and the rpm values and chart them one by one). I need to get the 5 outputs out of the for loop so that I can make a sub vi  which has 7 inputs and 5 outputs.
Message 5 of 9
(3,103 Views)
Hi ardahatunoglu,
using my recommendation from above you will get a subVI with 5 inputs. All you need to do is to add two more inputs and 5 outputs (which is very basic LabVIEW stuff)!
How to add those inputs/outputs to VIs is explained in the Training resources offered in the header of this LabVIEW board.
I guess you already noticed them and started to learn LabVIEW!?
Message 6 of 9
(3,098 Views)
Uhhhh.  It's not attached.
Message 7 of 9
(3,086 Views)
because it's in the first message
Message 8 of 9
(3,078 Views)
Okay.  Thanks.
It wasn't obvious since that message was edited.  And your second message set it was attached, that implied it was attached to THAT message.
Message 9 of 9
(3,064 Views)
