Taking pulse output from DAQ
Hi
I am working on 'wireless sum tracker module' project using LABVIEW; but I don't know how can I provide pusle to my circuit using LABVIEW.I was wondering if you can help me in this issue. please if possible tell me how can I connect my circuit to DAQ card to get pule.
Looking foeward to hearing from you,
Sincerely,
Monireh V
(2,810 Views)
(2,808 Views)
Hello Monireh,
To give you the precise solution we would need more inputs from you.\
But considering some assumptions from my side If you are using the Desktop PC for the project and If you are thinking of the DAQ card then,
You can go with the mulit-function  DAQ cards which have pulse generation capabilities.
You will also get the Details about the connections from the corresponding DAQ card Data Sheet.
http://sine.ni.com/nifn/cds/view/main/p/sn/n24:PCI/lang/en/nid/1036/ap/daq
you can choose a specific DAQ card for your requirement from the above link. (I have assumed that you will be using PCI cards)
Krunal K Patel
(2,802 Views)
