 BrianInTheFores
			BrianInTheFores12-04-2008 10:00 AM
I have some last minute questions about the CLD exam.
Are you or are you not given the Front Panel in LabVIEW when you take the exam or is the Front Panel just on paper? I have read and seen conflicting info on this.
Do you save your exam on the pc you are taking it on or are you given disks to save it on?
In a webcast on taking the CLD exam and in some material I have read, mastering different timing techniques is critical for a functional program in most CLD exams - would other previous CLD exam takers agree?
I can develop many types of state machines so I feel comfortable with coming up with an architecture. I am just concerned about the time of only 4 hours.
So my plan for tomorrow (based on what I have read in forums) is going to be:
1 Take time to read and understand the problem(5-10min)
2 Work out a solution on paper(20mins max)
3 Code the solution(2.5hours max)
4 Document and fine tune code(1 hour)
Is this a realistic strategy?
Any feedback or suggestions would be greatly appreciated
 Wiebe@CARYA
			Wiebe@CARYA
			12-04-2008 11:40 AM
 Darren
			Darren
			12-04-2008 11:46 AM
The exam paper can potentially show you a sample front panel, but when you code your solution, you will start with a blank VI.
To ensure no loss of work, your proctor will typically provide multiple storage mechanisms for your exam code, including disks, USB drives, and/or simply saving your work on the development machine.
Timing techniques is one of the skill areas listed in the CLD prep materials, so you'll want to be prepared in this area, just like all the others.
1 Take time to read and understand the problem(5-10min)2 Work out a solution on paper(20mins max)
If that's how you would code an app in the real world, then it's a realistic strategy. Some other people may prefer to document the code as they write it...some might forego spending 20 minutes on a paper solution...as long as you're comfortable with your own strategy, that's what matters.
Good luck on the exam!
-D12-04-2008 12:35 PM
Thanks Weibe and Darren for yalls input.
 TCPlomp
			TCPlomp
			12-04-2008 01:14 PM
Like Wiebe said being able to read english good enough is quite important (sadly).
I was done with my CLD after 2 hours. (and it was documented). Be comfortable with LabVIEW, I specially practised in setting up LabVIEW the way I like.
Create a backup of your LabVIEW.ini, delete LabVIEW.ini. Start LabVIEW, do some coding, find out which items irritate you (auto-wiring, auto exploding structures) try to set these items to your liking. Such a thing costs just 2 minutes but can save you a lot of frustration.
One tip:
Don't do anything fancy.
Ton
 Wiebe@CARYA
			Wiebe@CARYA
			12-05-2008 04:10 AM
12-05-2008 01:07 PM
Just finished the exam.
My program was working according to spec. Most everything has labels or documentation, still could of done a lot more.
Now the tough part - wating for the results.
 Wiebe@CARYA
			Wiebe@CARYA
			12-11-2008 06:10 AM
01-02-2009 03:24 PM
Just got my results.
I passed the CLD Exam!!!
 Darren
			Darren
			01-02-2009 03:28 PM
Congrats, Brian!
-D
