Tangent lines in XY graph
I have attached a picture in which i have to find the cutt frequency, the Y axis is the amplitude and X-axis is the frequency.
The red lines in the picture is the tangent lines, how would i make it visible in the graph and find the intersection point of both of it to calculate the cutt off frequency?
Thank you have and stay healthy.
(2,279 Views)
Hi Pukhtun,
This is rather basic math knowledge!
Determine slope/intersection of both tangent vectors. (You may use some interpolation function on a subset of your plot point data.)
Then calculate their crossing point. (You may use some of those mathematics functions…)
What have you tried so far? Where are you stuck?
(2,274 Views)
I tried it but could not find the correct VIs to implement the method.
How can i take two lines from a single graph ?
It seems to be quiet confusing for me
(2,257 Views)
Hi Pukhtun,
I repeat: "use some interpolation function on a subset of your plot point data"
See this:
As you use a logarithmic X axis it might help to apply a log() function on the X data before interpolation…
(2,250 Views)
Maybe you can find a mathematical model that describes your curve and fit to it after which you can determine  the interesting parameter.
(2,222 Views)
@GerdW wrote:
See this:
nice!
(2,207 Views)
