Tank Filling and Emptying
I cannot successfully convert to 8.0, because of missing "multisegment pipes". Also the in-place structure is not available in 8.0
A typical toplevel program program has an outermost while loop. the case structure needs to be further in. 😉
Message 31 of 37
(1,616 Views)
yes, one more case structure is needed when i'll be adding the slide thing...but for time being i just want to increase and decrease the level of water in tanks A and B in steps...can you please correct my work and attach a jpg file of the corrected work????
i am demanding too much, isnt it?? 😛
really sorry but i have to learn this software by any means......labview is driving me crazy.......i just wish that i will also be able to program like you, tbob, dave and others some day...i have gone crazy after seeing the tankfill VI attached by tbob....:)
regards rohini..
Message 32 of 37
(1,609 Views)
What is the meaning of "in steps". You are not very clear.
  • empty and fill automatically with the step size set by the slider?
  • the slider varies the two tank levels manually?
Message 33 of 37
(1,601 Views)
by steps i mean gradually....slider is just the pipe through which the water will flow...i will program that part later...
Message 34 of 37
(1,595 Views)
Message 35 of 37
(1,592 Views)
thanks a ton altenbach........now i can have my dinner peacefully.... 🙂
Message 36 of 37
(1,585 Views)
Good. I am about ready for brunch... 😄
Message 37 of 37
(1,580 Views)
