Tank double labels
I want a Tank with labels on both its sides. One indicating the percentage filled and the other one Litres. How can I do so?
Thank you.
(3,391 Views)
Like this???
CLD Using LabVIEW since 2013
(3,367 Views)
Hi Kartik,
I mean the numbers which are currently on the left side. I don't know what to call them.
Scale bar? degree label?
Like a diagram with two Y axes, indicating two different units.
(3,362 Views)
(3,349 Views)
Accepted by topic author Erfaan
If the % axis is static and always goes from 0% to 100%, just use a free label.
(3,310 Views)
Thanks AeroSoul,
It seems cool. I will try that.
(3,270 Views)
Thanks, Mr. Altenbach.
Yes, this will solve my problem. I had not thought of this; I thought I must add something like the genuine label.
Best wishes.
(3,269 Views)
