Tank numeric display precison from DAQ assistant
My tank display is connected to a DAQ assistant. I want to change the numeric display decimal places of the tank value from 6 to 2 (9.44223 to 9.44), but no matter where i adjust in tank properties, no can do.
Did i miss something? Advance thanks. :smileysurprised:
(3,115 Views)
Accepted by topic author sunflower2772
Hi sunflower,
I also didn't found an option in the properties dialog, but you can try this:
setprec.png (hmm, LV2009 changes the property node of one tank to a generic reference/property node...)
Or right-click the digital display -> create property node -> DisplayFormat or FormatString Smiley Wink
(3,106 Views)
