Tare function DAQ assist and restart function for the vi program
Hi!
I have a program that aquiers a signal from the DAQ assist. I have searched here on the forum and on the web, but I can't find a way to implement a tare function. The signal is from a loadcell and therby it would be good if Icould tare the signal to value zero. In the DAQ assist I can calibrate it manually, but i would like to wire this function to a button.
Also I have another problem that shouldn't be hard to solve, but I'm struggling with it. I want a resert function in my labview code so that i can restart the program from the begginging. I have used a case structure with normal and restart enum constant, and wierd them via a tunnel. But it dosn't seems to work. Instead of resetting the program it only stops it
I have attached my code below.
Best Regards Maurlind
Message 1 of 22
(9,222 Views)
Hi maurlind,
Well, often this function is called "Zero" - and often this was discussed here in the forum…
You need to store one measurement value (in a shift register) and subtract it from following measurements!
Usually you put your main part of the program in a loop that runs until you stop it with a condition of your choice…
Message 2 of 22
(9,212 Views)
How do you store a live signal and subtract it?, i have seen people who manage to zero a counting timer, with the help of an array and **bleep** register. But how can I do this with a signal ?
I don't know how to take the signal and subtract it with an offset.
With the reset function:
I know that I have to put a loop in the main part of my code, but I have a hard time to get my condition to work.
Best Regards Maurlind.
Message 3 of 22
(9,189 Views)
Hi Maurlind,
you really need to learn how to use (and spell :D) shift registers.
Go through those free LabVIEW beginner courses offered by NI - and through all those example VIs coming with LabVIEW!
Message 4 of 22
(9,187 Views)
Hi Maurlind,
maybe you can team up with JM?
Message 5 of 22
(9,177 Views)
Or the revived old thread at http://forums.ni.com/t5/Multifunction-DAQ/Zero-strain-readings-at-the-start-of-a-test-using-Daq-Assi...
Sounds like multiple students with the same assignment.
Message 6 of 22
(9,172 Views)
Message 7 of 22
(9,162 Views)
I solved my problem with the tare function, i used a case structure and shift register to store values in it. se picture below.
I haven't found a way to restart my VI yet. I tried to implement something from the community , see this link: https://decibel.ni.com/content/docs/DOC-4747
But that doesn't work for my VI and i don't know why. Could someone explain why doesn't work ?
My goal is to restart my whole VI with a press of a button.
Message 8 of 22
(9,131 Views)
Hi Maurlind,
I appreciate cleaning up a VI before uploading as a kind of respect for this forum…
You really should read the Design Guidelines in the LabVIEW help!
Could you please attach your VI in LV2011?
Usually you need a loop and a case structure wired to your button - similar as shown in that linked example…
Message 9 of 22
(9,120 Views)
Here is the program in LV 2011
I know my code is a bit off and need alot of polishing, but i have only worked with Labview for a month or two, so I'm still learning.
Sorry for any inconvenience!
Best Regards Marulind
Message 10 of 22
(9,116 Views)
