Target to Host DMA FIFO on a NI 9144 Expansion Chassis (EtherCAT)
I was of the opinion that some of the the expansion chasses would work with DMA fifo. the difference was that with ethernet it isnt deterministic and with etherCAT it is deterministic. I havent determined yet if this means that you can only use Scan mode with etherCAT.
David Raji
Message 11 of 11
(465 Views)
