Targets and Devices option not visible on right clicking My computer
I am using Labview FPGA module for the first time.
I have an NI Pxie-7846R (R-series) module stacked in a Pxie-8880 chassis.
To create an application using an FPGA target, I am following below instructions
(https://zone.ni.com/reference/en-XX/help/371599P-01/lvfpgahelp/adding_an_fpga_target/#Add_Remote_Tar...)
Adding an FPGA Target in the Local Development Computer
1. Create a new project or open an existing project.
2. Right-click My Computer in the Project Explorer window and select New»Targets and Devices from the shortcut menu to display the Add Targets and Devices dialog box.
I want to add the R-series module to My computer
However I am not able to see "Targets and Devices" option on right-clicking My computer. (It is visible on right clicking Project root).
In Ni Max, under Devices and Interfaces, the 7846R is visible.
Also I am using Labview2018 32 bit with FPGA module and Real-time module,
along with NI R Series Multifunction RIO 18.0.
Which is sufficient for running FPGA for R series as per (https://www.ni.com/en-in/support/documentation/compatibility/09/software-support-for-compactrio--com...)
Please help me adding the FPGA target.
(3,289 Views)
Try to right click on the project name itself right above the My Computer.
My Computer is already a target of its own, your local computer. You want to add a new target, so this is going to appear alongside My Computer, not inside of it.
Rolf Kalbermatter  My Blog
(3,254 Views)
Thanks Rolfk,   
However, on right-click on Project, I am not able to see 7846R on the list of either 'Existing targets or devices' or 'New targets or devices'.  In NI Max the 7846R is visible.
What do I need to do, in order to 7846R to appear in Target or devices?
(3,239 Views)
Accepted by topic author sumit_01
You need to install the according drivers AFTER you installed LabVIEW, LabVIEW RT and LabVIEW FPGA.
This must be at least NI-RIO in the same or newer version than your LabVIEW version and possibly extra hardware specific support such as FlexRIO and similar drivers.
(3,233 Views)
Thanks rolfk,
I installed the NI RIO driver after the installation of Labview, Labview RT, Labview FPGA.
Now I am able to add R series under My computer.
(3,214 Views)
Hello Rolf/Sumit,
I have the same issue but even after installing the drivers I am unable to see it in the project.  I have LabVIEW 2021 64 bit software.  Does the module only work for 32bit?
JT
(2,807 Views)
It is very helpful the solutions shown in the replies. I was perplexed for a few days by this problem and it is solved now. Thank you all.
(1,790 Views)
