Targets\instr.lib LabVIEW installation error
I´am suddenly having a problem with running projects in my Labview. I´am not aware of moving files or libraries, one day everything was working fine, next day i got this error. I´ve read few posts here (one similar but it did not help me) , reinstall whole program (labview, toolkits , real time modul , all updates), spent hours now to try fix this, but in the end i need help. If somebody has any idea, please let me know, my only idea is to reinstall this again. Still I´am not able to run this. It looks like problem with my Myrio library. Basic VI is working. Maybe it´s important to say, myrio device is working, wizard and everything. But after creating a new project i´ll get this message:
Thank you for any ideas. Adrian.
(3,128 Views)
Hello there!
You could try a force reinstall of the software.
I would force reinstall the MyRIO library first. restart the PC and then check again. if It did not work, you will probably need to force reinstall LabVIEW and then the modules, then toolkits, then drivers.
Restart the computer after each successfully forced reinstallation.
(3,068 Views)
