Task: Saving for LV 6.1
Hallo,
can somebody please convert the attached VI (LabVIEW 7) so that I can open it with LabVIEW 6.1?
Thanks a lot, Arno
(2,616 Views)
If you have LV 7.0, you can select save VI with options for opening the VI in 6.1 version. Remember that you cannot go back to 6.1 if you have LV 7.1.
I have attached 6.1 version of your VI here.
(2,616 Views)
The VI works, thanks, but not good enough. See what it does:
1,0E-6 1,0E-6 --> 1.0e-6 1,0E-6
What I need is a VI that replaces ALL ","'s and "E"'s in the string. Does anybody have a better idea?
Arno
(2,616 Views)
The Search and Replace String function has an input called "replace all?". The default is false. Wire a true to it. Right clicking on the function and selecting Help would have gotten you this information.
(2,616 Views)
