Task scaling failed on NI 9205
I have created a voltage task with MAX with the scale Y = 80 * x + 0. To test the scaling, I took a 50 Hz sinus voltage signal of 1.4V pp. If you do not select any scaling, the signal will be error-free shown. If the signal is scaled, it will be faulty.
Messung_ohneSkalierung_NI9205Messung_ohneSkalierung_NI9205Messung_Skalierung_Fehler_NI9205Messung_Skalierung_Fehler_NI9205
The same test I have made with the NI-6008 and it works without error.
Messung_Skalierung_NI6008Messung_Skalierung_NI6008My code you will find in the attachment.
Message 1 of 1
(2,299 Views)
