Taylor expansion of e^x
I’m currently a student tasked with programming in LabVIEW, though I have very little experience with the software. As a test of my understanding, my professor has assigned me to calculate the Taylor expansion of e^x. However, I'm not allowed to use the factorial or summation functions. I’ve tried implementing this with a stacked sequence structure and local variables, but I'm struggling to simplify the calculations. Any guidance would be greatly appreciated, including recommendations for helpful learning videos.
Message 1 of 13
(1,699 Views)
I can guarantee you that  stacked sequences and local variables will not be part of any reasonable solution! How do you come up with these crazy ideas?
@GradTA wrote:
As a test of my understanding,....
It is obvious that this test shows that you don't have any understanding yet!
Did you go over your course notes?
Did you look at the learning resources listed at the top of the forum?
Message 2 of 13
(1,692 Views)
That idea was given to me by the professor. Also when I click the link you posted it sends me to an error
Message 3 of 13
(1,688 Views)
As an example of a Taylor series expansion for sin(x), you could study this post. Now just modify the terms to approximate e^x instead, which is even simpler. See how far you get.
Message 4 of 13
(1,682 Views)
Sorry about the broken link. I have edited it out. Study the links in the above post instead.
Message 5 of 13
(1,678 Views)
You need to learn about Loops (For, While) and the three ways to get wires in and out:
  1. Tunnels, shown as filled squares color-coded according to the type of data going in or out),
  2. Array "take-apart" and "build" (the left Array tunnel returns Array elements, while the right Array tunnel "builds Arrays".
  3. Shift Registers -- takes outside input only on the first go-round, and puts the value on the right Shift Register back on the left one for the next go-round.
Now make yourself a For Loop, wire "10" to N (so it runs 10 times).  Experiment putting numbers (start with 1) into a Tunnel, and bring it out through a Tunnel, and through an Array tunnel (you can branch the wire inside the For Loop and make it go to two places.
Run this and observe the outputs.  Now put a function (say Increment) on the wire and see what happens.  Finally, add a Shift Register and see how it differs.
Pretty soon, you should be able to figure out how to put a quantity ("x") on the left, and get x^n/(n!), how to build an array for n = 1 ..10, and maybe how to add up the elements of this array.
Bob Schor
Message 6 of 13
(1,667 Views)
@altenbach wrote:
As an example of a Taylor series expansion [...] modify the terms to approximate e^x instead, which is even simpler
nice!
Spoiler
now get rid of the add array primitive...
n=6 n=20 n=100
Message 7 of 13
(1,625 Views)
From the original post:
"As a test of my understanding, my professor has assigned me to..."
Giving a direct solution could falsify the test of "understanding", unless the student can justify every minute detail of every single code element.....
Fortunately, the professor reads these forums too, so I am sure he will ask for a detailed explanation.. 😄
Message 8 of 13
(1,617 Views)
as usual, I have put in some characteristic mistakes, eg I use the add array elements primitive which may be interpreted as a summations function 😉
@GradTA wrote:
...  my professor has assigned me to calculate the Taylor expansion of e^x. However, I'm not allowed to use the factorial or summation functions.
moreover, when I tried to get rid of the add array elements primitive by using shift registers, the result tends to be less accurate when compared to the exp(x) primitive  (starting with the 16th decimal place)
I wonder if this is due to power of x primitive, which of course could be replaced by multiplications primitives as you (altenbach) did here
Message 9 of 13
(1,570 Views)
I would think that the "power of x" function should not be allowed here. Just basic primitives (add, multiply, divide).
You immediately get problems for "large'ish" absolute inputs where the division approaches Inf/Inf
Here's what I might do:
Message 10 of 13
(1,560 Views)
