Technical Inquiry: Multi-Protocol TSN Gateway Implementation on CompactRIO FPGA
We are planning to build an industrial gateway using an NI CompactRIO. We want to use the FPGA inside the CompactRIO to make it fast and reliable.
We need the FPGA to handle all of these protocols:
  • Current Protocols:
    • EtherCAT Master
    • PROFINET Controller
    • CC-Link IE
  • Future Protocols:
    • EtherCAT over TSN
    • PROFINET over TSN
    • CC-Link IE TSN
We have a few questions:
  1. Do you have ready-to-use code (IP cores) for these protocols that work with LabVIEW FPGA? We especially need the versions that work with TSN.
  2. If this is possible, can you recommend the best CompactRIO models for this job?
Any information or help you can provide would be greatly appreciated.
Thank you.
Message 1 of 1
(587 Views)
