All "getting started" VIs are pretty high level application programs that are intended to show someone how to do an entire instrument session. The driver has several low level functions that permit you to do repeated acquisitions without doing all of the configuration functions each time. Open up the subVIs in the example and look through them and look at the functions on the palette. There's VIs like tktds1k2k Read Waveform, tktds1k2k Fetch Waveform, tktds1k2k Initiate Acquisition, tktds1k2k Send Software Trigger, etc. that can be used.
