Tektronix TDS 784C Driver for LabVIEW 5
Application Examples is what I said and Application Examples is what you have. What is confusing about that?
Message 21 of 26
(1,158 Views)
hi, how can i create a function where im able to decrement a value with respect to time. meaning that if i have a value of 100 then it will slowly decrease by 1. say 100...99..98..97..96..95 till 0??
Message 22 of 26
(1,117 Views)
Hope this example may help you to understand it.
Mark M.
National Instruments UK & Ireland
Message 23 of 26
(1,096 Views)
Thanks Mark M for the decrement example. How do i an array which will feed the data into a case structure that will execute the process inside the array? for example i have 4buttons Ready, Set , Go , Run. if i click all 3 buttons (ready set go) and then press run it will execute it. and if i just click Ready , Go. it will skip the Set and run just the 2 operations. My idea is by using array to select the case. any ideas?
Message 24 of 26
(1,084 Views)
I have installed driver for tektronix labview 8.2 with lab top and usb wire
then i used the example in the driver to acouring the signal
but the laptop shows one messege that (tektronix is CAMIRA NOTWOTK SCAN)
and the driver of camira started  defined tektronix as camira
any help please
Message 25 of 26
(862 Views)
Hi H C U,
As this thread is now relatively old, I would suggest that if you were post your question in a new thread, you would receive a far better response. I would also recommend including a link to this thread in your new post.
Best Regards,
Christian Hartshorne
NIUK
Message 26 of 26
(851 Views)
