Tektronix TDS3014B
I am trying to control a Tektronix TDS3014B oscilloscope with the tkds30xx IVI
driver, and unfortunately the TDS3014B is different enough from the TDS3014
that it doesn't seem to work. Has anyone found out what changes need to be
made to the tkds30xx driver to get it to work? Any input would be appreciated
greatly.
Pete
Posted from host-64-65-245-26.choiceone.net [64.65.245.26]
via Mailgate.ORG Server - http://www.Mailgate.ORG
(2,851 Views)
Pete,
Since TDS3014B is a very new instrument, National Instrument still didn't evaluate all of its functionalities. We will look into this and decide whether we will make a new driver.
In the meantime, you may try un-checking the ID querying, so that the VI will not look for only 3014B.
You may also contact Tektronix and see if they can provide you with the information on what they changed in this new series and if they have a driver and VIs for the new instrument.
Sorry for the inconvenience.
Zvezdana S.
(2,851 Views)
