Temperature Control using labview
I am going to throw this out there just because...
Whenever you are controller heating elements you MUST have a hardware over temperature cut off in your system.
Don't learn this the hard way like I did. 😛
=== Engineer Ambiguously ===
Message 11 of 27
(4,176 Views)
Hi Shalalas,
Did you complete the project?
If yes, can you please send me the .vi file for reference.
I would be really grateful.
Message 12 of 27
(2,926 Views)
Hi Mahmudul,
Please consider message #10 to start your development.
What exactly are you looking for?
Message 13 of 27
(2,922 Views)
I am looking for  its complete solution for reference as i am working on similar project.
Message 14 of 27
(2,913 Views)
Hi Mahmudul,
It's impossible to get a "complete solution" for your "similar" problem!
Why don't you take the approach from message #10 and add your Keithley PSU commands as needed?
Message 15 of 27
(2,907 Views)
Message 16 of 27
(2,925 Views)
Hi mahmudul,
looks like configuration of the measurement...
Message 17 of 27
(2,917 Views)
i am facing a problem in outputing the current in the keithley power supply 2260B 250-9 remotely
can someone please help me with it. In the example given in the labview i only get the ouput voltage level and current always gives the value 0
Message 18 of 27
(2,975 Views)
I'm not an engineer, but I wonder if your Power Supply is connected to a load ...
Bob Schor
Message 19 of 27
(2,958 Views)
In my program the DAQ reading is not updating. While the loop runs, the DAQ only gives the first value while the others are not updated in the second iteration of the while loop.
Message 20 of 27
(3,034 Views)
