Temperature against time
Hi, I'm working on measuring temperature against time in labview (of a thermistor). The data comes in as voltage and gets converted to temperature in the subvi. I'm not sure whether I should be using a waveform or XY graph for this. I've attached the block diagram and subvi.
Thanks!
(4,374 Views)
Hi ehalpin,
You should be sure about your requirements!
So what exactly do you want to display?
Waveform graphs are perfect for evenly-sampled data (fixed dt), while XY graphs are nice for data with random X coordinates. (You might also use waveform graphs for non-evenly spaced data when using the waveform datatype…)
Why do you need 2 local variables just to display data in the waveform graph?
(4,347 Views)
Hi, thanks for the reply. I need to log a change in temperature over time so the waveform seems like the best option then!
Local variables were left over from something else I had tried out. Would it be better to just remove those?
(4,344 Views)
Accepted by topic author ehalpin13
YES!
You might want to consider moving the DAQ reading/logging into a parallel loop so it is constantly running and gathering data.  You could change your graph into a chart then and make things simpler.  You should also make sure your DAQ is set to be continuously running at a set rate (DAQmx Timing VI).
(4,339 Views)
If you're looking to add a data points to "waveform" over time, it sounds like job for a Chart.
There's an article here on the difference between Graphs and Charts in LabVIEW.
Patrick Allen: FunctionalityUnlimited.ca
(4,334 Views)
I use X-Y charts 99% of the time even though they are a bit more cumbersome, I like having complete control over how the data is presented.
=== Engineer Ambiguously ===
(4,316 Views)
