Temperature control - what type of PID controller to use?
Hello friends,
Im trying to make a VI program in which i could control temperature using the PID controller. I want to control temperature by choosing the PID gains by myself, and also with possibility of auto-tuning.
In LabView there is a lot of types of PID controller and i have a problem which should i use to control temperature? Is the PID Autotuning (temperature).vi is the right function to use?
Thanks for any answers.
(2,111 Views)
Hi Milos,
I never used those Autotune options, but determined PID gains by myself so I recommend to use the PIDAdvanced…
(2,088 Views)
I have only done this once and use the regular "PID.vi" and tuned it by hand. There is a cluster you can bring out to adjust the gain, integral time, and derivative time.
I have never had good luck with auto-tuning a PID. Even our expensive Thermotron thermal chambers auto-tune is basically worthless. I have spent days at a time following their auto-tune procedure. But it still ends up dramatically over shooting the set-point, when transitioning from cold to hot.
A few hours hand tuning and it will go from -40C to +120C with  <5 degrees over shoot. The best their auto-tune could do was about 20 degrees.
=== Engineer Ambiguously ===
(2,067 Views)
Is that analogous to the LabVIEW BD Cleanup tool?
Bill
CLD
(Mid-Level minion.)
(2,034 Views)
