Temperature dependent change of inductance
I have this circuit set up with resistor, thermometer (thermocouple) and inductor. I am supposed to build a vi to measure temperature dependent change of inductance. The main problem I am facing is with measuring the resistance of the inductor coil which also changes with temperatue.  I need to setup a DC circuit which measures the resistance then feed that information into ac circuit and measure impedance. If someone has any working ideas or similar experience, please forward.
Message 1 of 1
(2,767 Views)
