Temperature measurement with LV...
Will this NI system work with my LV 8.0 Profesional edition?
NI USB-9211A
http://www.ni.com/temperature/high_accuracy.htm
Message 1 of 10
(4,016 Views)
There's no reason why this fairly recent NI device wouldn't work with 8.0. Do you have a specific issue with the device?
Message 2 of 10
(3,980 Views)
No, I just wanted to make sure it will be controllable via my LV 8.0 before my company will buy this device.
Thanks.
Message 3 of 10
(3,977 Views)
They couldn't BE more compatible! Smiley Very Happy
Message 4 of 10
(3,974 Views)
I've never seen NI products not being compatible between HW & SW.
Maybe if the HW is newer and does not support older vintage of software products.
ie DAQmx and LV5.1 (maybe??)
R
Message 5 of 10
(3,973 Views)
I am using LV 8.5, but my laptop have intermitten problem detecting the usb-9211A.
I have only 2 usb ports, thus the 9211a have to got thru a usb hub. From what i know, this might only constrain it speed, but MAX can't even see 9211a. Any idea what might be the cause?
LC
Message 6 of 10
(3,808 Views)
What version of NI-DAQmx do you have?
Claire Reid
Message 7 of 10
(3,771 Views)
DAQmx 8.6
Message 8 of 10
(3,754 Views)
oetcl,
please do not hijack threads for your own questions. Please post new questions in new threads.
Nevertheless a question from my side:
I understand it that you have connected the USB 9211a using an USB hub. Is the device recognized correctly if connected directly to the laptop?
hope this helps,
Norbert
Message Edited by Norbert B on 02-24-2009 09:09 AM
Norbert
Expert: Geometry
Message 9 of 10
(3,751 Views)
RSibagatullin...What version of DAQmx do you have?
Claire Reid
Message 10 of 10
(3,744 Views)
