Temperature programmed desorption
Does anyone have any experiences with temperature programmed desorption
spectra taken with Labview?
Any help would be appreciated
Christian Ammon
Christian Ammon
Friedrich-Alexander Universitaet Erlangen
Physikalische Chemie II
Egerlandstrasse 3
D - 91058 Erlangen
Tel: +49 (0)9131/ 85- 27337
Lab: +49 (0)9131/ 85- 27315
Fax: +49 (0)9131/ 85- 28867
e-mail: christian.ammon@chemie.uni-erlangen.de
Der Letzte macht das Licht aus!
In a world without fences who needs gates?
Message 1 of 9
(5,695 Views)
What kind of problem do you have? I have not carried out exactly what
you want, but I cannot see any obstacles on the way.
Best wishes.
---Dmitry.
Christian Ammon wrote:
> Hi,
> Christian Ammon
> Christian Ammon
> Egerlandstrasse 3
> D - 91058 Erlangen
aus!
Message 2 of 9
(5,695 Views)
I am also looking for Temperature programmed desorption software written in lab view.
Madhu
Message 3 of 9
(5,503 Views)
Madhu,
Could you please expand upon your application.  LabVIEW likely does not have built-in VIs for temperature desorption, but it should provide the tools for you to write your own.
Mark
NI App Software R&D
Message 4 of 9
(5,486 Views)
Hi Mark,
I am using RGA100 from stanford Research System which gives me partial pressure of the desorbing gases. For temperature controller  I am thinking of using waltow eries 96 controller. For my temperature programmed desorption I need partial pressure, time and temperature as output and temperature should increase linearly with time.
Is it possible to use labview to achieve this task?
Madhu
Message 5 of 9
(5,470 Views)
I believe you can use both of those instruments and control them using LabVIEW.  Please let me know if these drivers will work for you application.
Stanford Research PPM100
I'm not completely sure which driver will work for the second instrument but here are all the avaliable drivers from that vendor.
Watlow Drivers
All of these drivers are avaliable on our website and are searchable by selecting Browse Drivers »
Mark
NI App Software R&D
Message 6 of 9
(5,456 Views)
Hi Mark,
Thanks for your reply. Do I have to buy PPM100 from Stanford Research System to use the driver that you referred me to use  or I can use this diver for RGA100.
Madhu
Message 7 of 9
(5,445 Views)
Hi Mark,
Madhu
Message 8 of 9
(5,445 Views)
I am not sure.  I would recommend downloading the drivers and see if they will work with your instrument.
Mark
NI App Software R&D
Message 9 of 9
(5,429 Views)
