03-21-2007 11:25 AM
03-22-2007 10:16 AM
03-22-2007 11:51 AM
03-22-2007 12:00 PM
03-22-2007 12:04 PM
03-22-2007 12:15 PM
Hello Nishant.
You can use the PCI-4452 to read temperatures from a thermocouple. I would recommend measuring the input differentially. The other advantage that the 4452 gives you are the software configurable input ranges. Since you are measuring a thermocouple, as long as the temperature doesn't get too hot, you could use the .316 V range. If you are measuring hotter temperatures, then you could use the 1 V range. This will allow you to apply the 16 bits of resolution that the card provides across a smaller range and effectively increase your resolution even more.
In terms of getting started with a program to take these measurements, I would recommend finding a simple analog input example program in our NI Example Finder. NI Example Finder provides numerous VI's that are pre-built for basic applications. There are many VI's which use the DAQ drivers to acquire a voltage on a channel, which could be used for your application.
Brian F
03-22-2007 05:08 PM
