Temporary storage
Sorry if my question is too basic.
I currently need to create a temporary storage to store my current input distance (ex:8cm), after that i will key in the new input (ex:10cm). I tend to use the stored 8cm to compare to the new input -- 10cm when i input the 10cm to make the system create a displacement profile just for 2cm (10-8).
So may i know how to create a temporary storage to store the value and the value will keep replacing once i enter new input ?
Shawn
(3,838 Views)
Accepted by topic author shawn chew
You may want to take a look at my Action Engine Nugget. Action Engines let you store and share data. THey are based on Shift Registers which also may be of use in your app.
Just trying to help,
Ben
(3,828 Views)
Thank you so much ben. Appreciated ur help
Shawn
(3,740 Views)
