Temptronic Labview Driver?
Does anyone have a labview driver for a Temptronic TP0412A Temperature forcing system? Or something similar?
Thanks in advance
Tester
(2,890 Views)
Doesn't look like you got any responses from your earlier query for drivers on this. Try the ones posted in this thread. If those don't work, writing an instrument driver is not that bad. LabVIEW 8.20 has a built-in "wizard" that creates a template that you can use.
(2,880 Views)
