Ten Analog inputs (4-20 mA) transmitted wireless
Hello. I'm Sorin, from Romania. I am engineer at Icemenerg, Bucharest.
I need to aquire 10 analog current signals 4-20 mA. (temperatures,levels, etc in
situated in opened field). These signals are faraway from my computer (300 m), so i
must do it wireless somehow. My thought was to use a single device (Converter) with
at least 10 analog inputs (4-20mA), and a numeric output. Then the numeric signal to
be sent wireless to 300m, to my computer, where there is a receiver with eventually
one USB output port.
Then Labview 8.5 will do the rest.... Can you tell me, if you have such a device
/system ? The Converter is the key.
I made a schematic in attachement.
Message 1 of 9
(5,081 Views)
NI makes wireless products.  Look at the NI.com homepage and search from there.
Here is a link to a page that is only two clicks away.  http://sine.ni.com/nifn/cds/view/main/p/sn/n24:Wireless/lang/en/nid/1036/ap/daq
Message 2 of 9
(5,070 Views)
Sorin:
NI recently released the WLS series, but they are voltage input only. You could convert the 4-20mA signals to a voltage by using a precsion resisitor. Do not know the transmitting range of the WLS series, also do not know how fast you need to sample. Another thing you may need to consider is full channel-to-channel isolation to minimize any ground loop issues.
http://sine.ni.com/nifn/cds/view/main/p/sn/n1:7850,n24:Wireless/sb/%2Bnigenso7/lang/en/nid/1036/ap/d...
There are many 4-20mA wireless transmitters (some with ranges of many km). Not sure what your budget is.
http://www.google.com/search?hl=en&source=hp&q=4-20ma+wireless+transmitter&aq=2&oq=%224-20mA%22+%2B+...
Hope this gets you started!
-AK2DM
Edit: I see Ravens Fan beat me to the first part while I was Googling around 🙂
Message Edited by AnalogKid2DigitalMan on 09-11-2009 02:51 PM
Message 3 of 9
(5,069 Views)
Sorin:
On second thought, 4-20mA signals should easily work with a 300m run of direct wiring, is that a viable option?
-AK2DM
Message 4 of 9
(5,033 Views)
Thank you all, for your answers.
Finally, I decided to do it wireless
Shortly, i have to aquire 4 temps and 6 currents (4-20mA) in the same time, at 1 S/s. The computer is 250 m away.
Which protocol is simplier to implement and to work to, ethernet (TCP/IP) or serial (rs-232) ?  Since now, i worked with serial.
I want that the programm .vi to be seen on many computers in a LAN. That's why i was thinking that TCP/IP is the best suited for my system.
So, what do you recomand ?
Thank's.
Message 5 of 9
(4,987 Views)
Hello Sorin,
If you're looking to perform a wireless acquisition, I recommend looking into our wireless DAQ devices as stated above. What software will you be using to communicate with the hardware.
Glenn
Glenn
Message 6 of 9
(4,963 Views)
I use Labview 8.5 professional edition.
I don't think wireless DAQ is best for my case.
DAQ module has only voltage inputs (or currents with additional precision resistors). I have to record temperatures and currents.
Also, the programm must run on a computer (server) and to be seen in LAN, JUST see, not control. So i need one simple system for aquisition.
I think i 'll use some transmitters with temperatures and currents inputs. And for the output i think is best tcp/ip protocol. My thought was that NI has such transmitters, althought i can find other brands here in Romania, with very good products.
I  made a schematic with my idea, in attachment.
And the big question was: is it tcp/ip protocol easier to implement (to programm) than serial RS-232, RS-485 ?
Thanks.
Message 7 of 9
(4,949 Views)
here is the schematic
Message 8 of 9
(4,947 Views)
Maybe using a Compact FieldPoint unit (ie cFP-1804) outfitted with some AI-110 modules. Note that the modules do not have a fast sampling rate. This could be connected to a wireless LAN link and your LabVIEW program running on a remote PC could poll the data via the LAN connection.
-AK2DM
Message 9 of 9
(4,913 Views)
