Terminal and cable compatible with pci - 6070 ? - Hardware config
Hello!
I want to make a stand learning for data aquisition .
I have an Industiral computer and pci - mio-16e-1(PCI - 6070) aquisition data device but i don't know what cable and terminal to use for this.
Tell me someone what should i use ?
Thanks in advance.
Best Regards,
Cosmin.
(1,154 Views)
Hi Cosmin,
this is some very old hardware…
Did you try to search the web for your hardware? When using Google to look for "pci-6070" it brings me (as first result) to the datasheet found at NI.com. And there you find a link to accessories
Did you try to call NI sales for support?
(1,140 Views)
