Terminal creation problem
Good Morning,
I have a program which is used to acquire the images through laptop web camera.
I want to create a sub vi of this program and use it in another program.
When I tried to edit the icon to make a terminal to select my camera it is not accepting. It says it is default "cam0".
Need help to create the terminal for choosing the camera.
Thanking you.
(2,610 Views)
I think this is because in the "session" terminal you can only chose a camera that is currently detected, what you can do thought is use a string control instead of the "IMAQ session ring", if you link a simple string control to the IMAQ configure VI I believe it will accept it and if the string value correspond to an existing camera name it will work.
Hope this helps
We have two ears and one mouth so that we can listen twice as much as we speak.
Epictetus
Antoine Chalons
(2,594 Views)
