Terminate flat sequence with queuing!
I am a beginner labview user. I am using a flat sequence that executes a olfactory connected to licking sensor and water pump. I have a problem in the fourth segment of the sequence where I think using queuing is the source of the problem. But I can't really figure it out. I would appreciate any help. Thanks a lot.
Best regardss.
Mostafa
(3,510 Views)
Don't use such a worm of a sequence, use a statemachine that fits on one screen. Most of your code makes no sense.
I would recommend you start with some tutorials before attemtping such a project.
(3,508 Views)
Diagram clean-up only makes it BIGGER.
Jim
(3,464 Views)
To learn more about LabVIEW, I suggest you try looking at some of these tutorials.
(3,454 Views)
Thank you very much guys. I made use of your advice. I just restarted the project again, and now it is working way better. Thanks a lot 🙂
(3,416 Views)
