Test Executive 5.1.1 Test Sequence reports a fail, but the view report shows a pass
The UUT is actually failing (it is a known bad part). Test sequence saves previous UUT test data and presents it in the sequence test report. After running the sequence a second time, test report indicates correct (failing) data. Test is using a HP34401A meter. All other test vi using this meter operate correctly. Seems to be this particular vi. But vi is running correctly when viewing the data passed out with a probe it is the correct data being passed out to TE.
(2,502 Views)
Snoopdog,
Unfortunately, the only support we offer for TestExecutive is what is available on our web pages at:
LabVIEW:
http://www.ni.com/support/labview/toolkits/testexec/
CVI:
http://www.ni.com/support/cvi/toolkits/testexec/
Best Regards,
Matt P.
(2,502 Views)
