Test PC performance for certain LabView program
I am interesting in how to check minimum PC performance for certain LabView program?
(4,503 Views)
Hi Laza22,
if you intend to monitor your CPU usage you can use this VI:
Monitoring CPU usage on Windows from LabVIEW
https://decibel.ni.com/content/docs/DOC-3728
Or did you mean you need some minimum specifications for your self created VIs?
Regards
(4,491 Views)
Hello EduardGross,
Thanks for response.
I need a way to find out the minimum PC specifications for self created VIs.
Best regards
(4,487 Views)
Sorry, posted in wrong topic 😉
(4,484 Views)
I would say to look up the requirements for the RunTime Engine.  If you think you need more processing power, increase your requirements some.
(4,465 Views)
Yes, but I am interested in, Is there a way to get this information more precisely?
(4,459 Views)
Hi, Take a look at this: http://en.wikipedia.org/wiki/System_requirements When I create programs I set the requirements equal to the Run-Time Engine requirements. Sometimes I create some functionality that requires specific hardware or software. I then just add those to the other requirements. If you need to find out what a computer need to run your program, I guess you have to test it out on a high-end and a low-end computer and check for a difference.
Even
_________________________________
Certified LabVIEW Associate Developer
Automated Test Developer
Topro AS
Norway
(4,452 Views)
