Test Panel in MAX for NI 9206 show BoardTempSensor, How can I log it?
Dear,
I am using the ENET-9206 and I need to log the temperature of the board.
The Test Panel in MAX show the channell named BoardTempSensor_vs_aignd but I can not create a Task with It.
Is It possible to log that channell in some way?
Which scale does It use?
(3,112 Views)
Hi!!
You can try something like this:
MarcoMar
National Instruments Italy
(3,070 Views)
I've tried but when I connect a control to the "Physical channel" input of the "DAQmx Create Channel (AI-Temperuature-Built-in  Sensor).vi" I can't chose any internal channel.
I can choose only beetwen ai0 ... ai3; no other channel appers in the browes.
Some other way?
(3,058 Views)
Hi!
Somebody can help me?
(2,986 Views)
