TestStand Sequence file MessagePopup
How to add MessagePopup step on TestStand Sequence using LabView programming?
(3,008 Views)
You don't want to use the built-in pop-up step? Top usr your own, just insert it as an action step. What problem do you have with that?
In the future, please use the TestStand board.
(2,992 Views)
