TestStand dll in LabView
Hello all,
I have never used llb before, so this might be a very stupid question. I was given a ASAP3.dll along with a .seq file. I made a screen cap of how it is use in TestStand here. Is there any way I can use the ASAP3.dll in LabView instead of TestStand?
(3,615 Views)
It's not an llb and since the dll requires the TestStand sequence context, you can't just use LabVIEW.
(3,609 Views)
What is a "TestStand sequence context"?
(3,600 Views)
From thr TestStand Help:
A sequence context is an object in the TestStand API that represents the execution state of a sequence. For each active sequence, TestStand maintains a sequence context you can use to access all the objects, variables, and properties that relate to the execution of the sequence.
(3,597 Views)
