TestStand to LV comunication
Hi folks,
I trying to understand how the communication between TS and LV works and to do that I' using
TestStand Status Monitor using Synchronization Objects - LabVIEW
Is not clear because if I change the data type send from TS to LV it doesn't work.
TS side I've changed the data send from Locals.CommandHistory (container type) to Locals.Message (Number type) and in LV dump out the information regarding the incoming data type.
Well, in the native case (container) work well and in the second case (number) LV site receive  the error code -17308
I've add the indicators to dump the data type from TS but in case of error seems that LV receive nothing
Someone have experience with this interface?
Message 1 of 1
(1,106 Views)
